Creating the rigging system
  Placing trusses
             Tool  |
             Tool set  |
             Truss
             Rigging  |
The Truss tool places a section of truss on the drawing. Depending on the resource selected, the truss may be a straight, curved (or circular), hinge, or corner element.
You can place one truss at a time, or place multiple straight trusses, to create a truss line. Trusses can be inserted horizontally, vertically, or at a custom hanging angle. In Auto Connect mode, the trusses connect to existing trusses, forming a system. When Auto Connect is disabled, the trusses do not connect to existing systems.
Use the Data Tag tool to add a label to the truss; see Using data tags.
             Mode  |
             Description  |
             Auto Connect
             When enabled, connects the inserted truss to the current truss system with geometrical precision; also generates a preview of connected trusses that are being moved  |
             Truss symbol  |
             Select the truss to insert  |
             Single Insertion
             Inserts a single truss object on the guideline  |
             Distributed Insertion
 (straight truss only)  |
             Inserts multiple truss objects along the full length of the guideline  |
             Horizontal Placement
             Places horizontal trusses; the hanging angle is 0 (zero) degrees  |
             Vertical Placement
             Places vertical trusses; the hanging angle is 90 degrees  |
             Custom Placement
             Places trusses at the specified Hanging Angle  |
             Maintain class of symbol
             Uses the class specification from the symbol definition; disable the mode to insert the truss into the active class instead  |
             Hanging Angle  |
             Specify the hanging angle for Custom Placement  |
A truss object whose symbol definition cannot be located will display with default geometry, until a replacement symbol is assigned.
